[osgeo4w-dev] [osgeo4w] #847: qgis-dev installs and uses both gdal-dev310.dll and gdal309.dll
OSGeo4W trac_osgeo4w at osgeo.org
Fri Aug 23 06:23:56 PDT 2024
Reporter:  andreaerdna  |       Owner:  osgeo4w-dev@…
    Type:  defect       |      Status:  new
Priority:  normal       |   Component:  Package
 Version:               |  Resolution:
Keywords:               |
Comment (by andreaerdna):
 What if qgis-dev and pdal use one or more GDAL/OGR functions that process
 data in a different way between gdal and gdal-dev?
 I suggest, in order to avoid possible issues, to use, for qgis-dev, a
 specific pdal-libs package that is build against gdal-dev, if possible.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/847#comment:2>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
