[osgeo4w-dev] [osgeo4w] #832: PROJ_LIB environment variable is deprecated
trac_osgeo4w at osgeo.org
Wed May 1 18:08:16 PDT 2024
Reporter: Mike Taves | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: normal | Component: Package
Version: | Keywords:
When using one of the PROJ utilities from an OSGeo4W Shell, a
DeprecationWarning message is shown at the top:
C:\OSGeo4W>proj
DeprecationWarning: PROJ_LIB environment variable is deprecated, and will
be removed in a future release. You are encouraged to set PROJ_DATA
instead.
Rel. 9.4.0, March 1st, 2024
usage: proj [-bdeEfiIlmorsStTvVwW [args]] [+opt[=arg] ...] [file ...]
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/832>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
