[osgeo4w-dev] [osgeo4w] #857: Perform initial speed test for the selected sources
    trac_osgeo4w at osgeo.org
    Mon Nov 11 00:42:45 PST 2024
Reporter:  Chau         |      Owner:  osgeo4w-dev@…
    Type:  enhancement  |     Status:  new
Priority:  minor        |  Component:  Installer
 Version:               |   Keywords:
 Hi Jürgen
 When I run the OSGeo4w setup I can select between 3 different sources:
 - OSGeo
 - OSUOSL
 - Norbit
 I guess the first two are in the US and yours are of course in Germany.
 When I select all three sources it seems like it uses the first source if
 available and download everything from there. Sometimes this works just
 fine but at other times downloading everything from the US to me in
 Denmark is very slow (at around 200-250kb/s compared to 1-2MB/s from
 Germany). With downloads like the `proj-data` the difference in transfer
 speed does matter.
 I could just select your Norbit source (and that is normally my solution)
 but I guess that this removes the redundancy in case your site should be
 down (I haven't seen that though).
 Would it be possible to implement a simple speed test towards the selected
 sources and then choose the source with the best transfer rate before
 downloading the request packages?
 Kind regards,
 Casper
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/857>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
