[osgeo4w-dev] QGIS Issues after latest update
    Jürgen E. Fischer
    jef at norbit.de
    Fri Nov 22 01:39:02 PST 2024
Hi Gandalf,
On Fri, 22. Nov 2024 at 10:17:20 +0200, Gandalf the Gray via osgeo4w-dev wrote:
> After updating the stack this morning (22 Nov), whenever I open a layer in
> QGIS LTR I do not see my projection, in stead I see Unknown CRS.
> I suspect it might be due to GDAL being updated.
Which GDAL update (the update to 3.10 is still pending)?  When did you update
last?
If you're refering to the GDAL nightly build: that's not used for QGIS LTR (or
QGIS) - only for master qgis(-qt6)-dev.
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden            https://www.norbit.de
QGIS release manager (PSC)  Germany                 IRC: jef on Libera|OFTC
Desc: not available
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20241122/7e92d5a1/attachment.sig>
More information about the osgeo4w-dev
