[osgeo4w-dev] [osgeo4w] #850: poppler/GDAL: image dithering when transforming vector PDF to raster image
OSGeo4W trac_osgeo4w at osgeo.org
Thu Sep 5 03:17:15 PDT 2024
Reporter:  andreaerdna  |      Owner:  osgeo4w-dev@…
    Type:  defect       |     Status:  new
Priority:  normal       |  Component:  Package
 Version:               |   Keywords:
 As reported at https://github.com/OSGeo/gdal/issues/10595.
 If it is not possible to fix the OSGeo4W poppler 24.04.0 build, or in the
 meantime that it will be fixed, I propose to downgrade the OSGeo4W poppler
 package to the previous version and rebuild gdal and other dependent
 packages in order to avoid the reported issue.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/850>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
