[osgeo4w-dev] KDE's maintained 5.15 fork and HAS_KDE_QT5_*_FIX switches
Andrea Giudiceandrea
andreaerdna at libero.it
Sun Apr 6 02:13:00 PDT 2025
are the OSGeo4W 's Qt5 builds built from the KDE's maintained 5.15 fork?
If yes, does it contains the "PDF brush transform" fix, the
"QFont::SmallCaps" fix and the "QFont stretch" fix?
If it's the case, could the HAS_KDE_QT5_PDF_TRANSFORM_FIX,
HAS_KDE_QT5_SMALL_CAPS_FIX and HAS_KDE_QT5_FONT_STRETCH_FIX
https://github.com/nyalldawson/QGIS/blob/master/CMakeLists.txt#L471-L473
be set to true for the OSGeo4W's QGIS builds in order to enable the
features introduced with https://github.com/qgis/QGIS/pull/45946,
https://github.com/qgis/QGIS/pull/45887 and
https://github.com/qgis/QGIS/pull/45827?
Regards.
More information about the osgeo4w-dev
