[osgeo4w-dev] [osgeo4w] #879: ogrinfo (gdal-dev) fails: MSVCP140.ddl error probably related to proj
trac_osgeo4w at osgeo.org
Fri Apr 25 07:40:00 PDT 2025
Reporter: andreaerdna | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: normal | Component: Package
Version: | Resolution:
Keywords: |
Comment (by andreaerdna):
Actually the crssync.exe, untwine.exe and pdal_wrench.exe errors occur
also for qgis and qgis-ltr if proj9-runtime 9.6.0-1 is installed, while
they don't occur after downgrading proj9-runtime from 9.6.0-1 to 9.5.1-1.
Also SAGA-GUI fails to start if proj9-runtime 9.6.0-1 is installed, while
it succeeds after downgrading proj9-runtime from 9.6.0-1 to 9.5.1-1.
I guess also GRASS-GIS could be affected by the same issue.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/879#comment:4>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
