[osgeo4w-dev] [osgeo4w] #898: PDAL algs and pdal_wrench.exe don't work in latest QGIS versions
OSGeo4W trac_osgeo4w at osgeo.org
Sun Dec 14 03:45:46 PST 2025
Reporter:  andreaerdna  |      Owner:  osgeo4w-dev@…
    Type:  defect       |     Status:  new
Priority:  normal       |  Component:  Package
 Version:               |   Keywords:
 PDAL processing algorithms (e.g. "Export to raster" or "Export to raster
 (using triangulation") and pdal_wrench.exe don't work in latest QGIS LTR
 3.40.13, QGIS 3.44.5 and QGIS 3.99.0-Master.
 The algorithm's execution log reports:
 QGIS version: 3.40.13-Bratislava
 QGIS code revision: 6c6bebb0e7
 Qt version: 5.15.13
 Python version: 3.12.12
 GDAL version: 3.12.0
 GEOS version: 3.13.1-CAPI-1.19.2
 PROJ version: Rel. 9.7.0, September 1st, 2025
 PDAL version: 2.9.0 (git-version: 42b180)
 Algorithm started at: 2025-12-14T11:57:59
 Algorithm 'Export to raster' starting…
 Input parameters:
 { 'ATTRIBUTE' : 'Z', 'FILTER_EXPRESSION' : '', 'FILTER_EXTENT' : None,
 'INPUT' :
 'copc://C:/Users/Andrea/Downloads/2034000_7275500_LIDAR2021.copc.laz',
 'ORIGIN_X' : None, 'ORIGIN_Y' : None, 'OUTPUT' : 'TEMPORARY_OUTPUT',
 'RESOLUTION' : 1, 'TILE_SIZE' : 1000 }
 wrench command: C:/OSE37B~1/apps/qgis-ltr/./pdal_wrench.exe to_raster
 --input=C:/Users/Andrea/Downloads/2034000_7275500_LIDAR2021.copc.laz
 --output=C:/Users/Andrea/AppData/Local/Temp/processing_TfzXfh/017254694c134706ad41d27cb61c8738/OUTPUT.tif
 --attribute=Z --resolution=1 --tile-size=1000 --threads=4
 0....10....20....30....40....50....60....70....80....90....100 - done.
 Warning 1: Can't open
 C:/Users/Andrea/AppData/Local/Temp/processing_TfzXfh/017254694c134706ad41d27cb61c8738\OUTPUT\0_0.tif.
 Skipping it
 Process completed successfully
 Execution completed in 2.43 seconds
 Results:
   OUTPUT:
 Loading resulting layers
 The following layers were not correctly generated.
 You can check the 'Log Messages Panel' in QGIS main window to find more
 information about the execution of the algorithm.
 The issues occurs also directly executing pdal_wrench in the OSGeo4W
 Shell:
 --output=C:/Users/Andrea/Downloads/exportedcopc.tif --attribute=Z
 Warning 1: Can't open C:/Users/Andrea/Downloads\exportedcopc\0_0.tif.
 Skipping it
 The issue doesn't occur if pdal_wrench.exe, provided by the qgis-
 ltr-3.40.13-1 package, is replaced with the one from the qgis-
 ltr-3.40.12-1 package.
 I suppose the issue may be due to the fact that while pdal_wrench.exe in
 qgis-ltr-3.40.13-1 is built against gdal312, pdalcpp.dll (which
 pdal_wrench.exe depends on) is still build against gdal311.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/898>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
