[osgeo4w-dev] [osgeo4w] #868: python3-rasterio broken in latest release
OSGeo4W trac_osgeo4w at osgeo.org
Wed Feb 5 09:25:06 PST 2025
Reporter:  Christina Ratcliff  |       Owner:  osgeo4w-dev@…
    Type:  defect              |      Status:  new
Priority:  critical            |   Component:  Package
 Version:                      |  Resolution:
Keywords:                      |
Comment (by jef):
 Replying to [comment:2 Christina Ratcliff]:
 > {{{python3-rasterio 1.3.10-1}}} is compatible with the above. Is there a
 switch for using the previous version when using the command line?
 Correct.  For the current python-rasterio you need the current gdal 3.10.1
 (and current QGIS 3.40.3).  For older version you can use the snapshots
 ([/#Olderversionsfromreposnapshots])
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/868#comment:3>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
