[osgeo4w-dev] [osgeo4w] #887: QGIS 3.40.8 LTR not opening on Windows 10 and 11
trac_osgeo4w at osgeo.org
Wed Jul 2 06:44:56 PDT 2025
Reporter: mattenvsys | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: normal | Component: Package
Version: | Resolution:
Keywords: |
Comment (by mattenvsys):
Hi jef, the issue is resolved but we are unsure what happened and how it
was resolved.
The original error resulted when was using the standalone QGIS-
OSGeo4W-3.40.8-1.msi and standalone QGIS-OSGeo4W-3.44.0-1.msi installers.
PDQ attempted uninstall 3.40.7 and then install 3.40.8 using QGIS-
OSGeo4W-3.40.8-1.msi. This resulted in the error message "Oops, looks like
an error loading QGIS" seen above when attempting to open QGIS.
After removing 3.40.8 I manually installed QGIS, again using QGIS-
OSGeo4W-3.40.8-1.msi, directly on the computer. This resulted in the
second error message "Windows cannot access the specified device, path or
file."
I then downloaded QGIS-OSGeo4W-3.44.0-1.msi to see if this would exhibit
the same issues before reporting the problem. After installing 3.44.0 I
received the same error, "Windows cannot access the specified device, path
or file."
We put this issue aside until we received feedback via the issue tracker.
However, as no one else seemed to be reporting the issue it seemed to be
localised to just us. We attempted to install QGIS using the a freshly
downloaded and the original 3.40.8-1.msi file once again and both installs
resulted in a fully functional QGIS installation.
So we are a bit stumped as to what happened as every user in the
organisation experienced the unable to open QGIS error.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/887#comment:4>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
