[osgeo4w-dev] [osgeo4w] #883: Doesn't gdal-dev build?
trac_osgeo4w at osgeo.org
Tue Jun 17 10:07:38 PDT 2025
Reporter: jratike80 | Owner: osgeo4w-dev@…
Type: defect | Status: closed
Priority: normal | Component: Package
Version: | Resolution: fixed
Keywords: |
Changes (by jef):
* resolution: => fixed
* status: new => closed
Comment:
Yes.
FAILED: alg/CMakeFiles/alg.dir/gdalrasterize.cpp.obj
C:\src\osgeo4w\scripts\vs2022\VC\Tools\MSVC\14.38.33130\bin\Hostx64\x64\cl.exe
/nologo /TP -DGDAL_COMPILATION -DHAVE_AVX_AT_COMPILE_TIME -DHAVE_GEOS=1
-DHAVE_SSE_AT_COMPILE_TIME -DHAVE_SSSE3_AT_COMPILE_TIME -DINTERNAL_QHULL
-DNOMINMAX -D_CRT_NONSTDC_NO_DEPRECATE -D_CRT_SECURE_NO_DEPRECATE
-IC:\src\osgeo4w\src\gdal-dev\gdal\apps -IC:\src\osgeo4w\src\gdal-
dev\gdal\alg -IC:\src\osgeo4w\src\gdal-dev\gdal\gcore -IC:\src\osgeo4w\src
\gdal-dev\osgeo4w\build\gcore -IC:\src\osgeo4w\src\gdal-dev\gdal\port
-IC:\src\osgeo4w\src\gdal-dev\osgeo4w\build\port -IC:\src\osgeo4w\src
\gdal-dev\gdal\ogr -IC:\src\osgeo4w\src\gdal-dev\gdal\ogr\ogrsf_frmts
-IC:\src\osgeo4w\src\gdal-dev\gdal\frmts -IC:\src\osgeo4w\src\gdal-
dev\gdal\frmts\mem -IC:\src\osgeo4w\src\gdal-dev\gdal\alg\marching_squares
-IC:\src\osgeo4w\src\gdal-dev\gdal\frmts\vrt -IC:\src\osgeo4w\src\gdal-
dev\osgeo4w\osgeo4w\include\geos -IC:\src\osgeo4w\src\gdal-
dev\osgeo4w\osgeo4w\include -IC:\src\osgeo4w\src\gdal-
dev\gdal\alg\internal_libqhull /D_DISABLE_CONSTEXPR_MUTEX_CONSTRUCTOR
/DWIN32 /D_WINDOWS /EHsc /O2 /Ob1 /DNDEBUG -std:c++17 -MD -Zi /EHsc /MP
/W4 /wd4127 /wd4251 /wd4275 /wd4786 /wd4100 /wd4245 /wd4206 /wd4351
/wd4611 /showIncludes /Foalg\CMakeFiles\alg.dir\gdalrasterize.cpp.obj
/Fdalg\CMakeFiles\alg.dir\ /FS -c C:\src\osgeo4w\src\gdal-
dev\gdal\alg\gdalrasterize.cpp
C:\src\osgeo4w\src\gdal-dev\gdal\gcore\gdal_priv_templates.hpp(401): error
C3861: '_mm_undefined_ps': identifier not found
C:\src\osgeo4w\src\gdal-dev\gdal\gcore\gdal_priv_templates.hpp(400): error
C2660: '_mm_store_ss': function does not take 1 arguments
C:\src\osgeo4w\scripts\vs2022\VC\Tools\MSVC\14.38.33130\include\xmmintrin.h(352):
note: see declaration of '_mm_store_ss'
C:\src\osgeo4w\src\gdal-dev\gdal\gcore\gdal_priv_templates.hpp(400): note:
while trying to match the argument list '(float *)'
Last good build was 75a784eecf and first broken 105b8c1175.
Fixed in
https://github.com/jef-n/OSGeo4W/696c879e5eb4a4fe1897cc9bf96be32a942962f0
See also https://github.com/OSGeo/gdal/pull/12586
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/883#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
