[osgeo4w-dev] [osgeo4w] #874: Add Enchant C-library to OSGEO4W
OSGeo4W trac_osgeo4w at osgeo.org
Fri Mar 14 15:14:32 PDT 2025
Reporter:  seewhy       |      Owner:  osgeo4w-dev@…
    Type:  enhancement  |     Status:  new
Priority:  normal       |  Component:  Package
 Version:               |   Keywords:
 Further to trying to solve a QGIS issue, I would like to request packaging
 of Enchant libraries within OSGEO4W so that it is possible to load
 pyenchant within QGIS.
 Currently pyenchant packages the libraries within its Windows version, but
 it is possible to install the package without the wheel binaries. Enchant
 looks in the system path if it can't find those binaries, so would
 presumably load them if included within the QGIS installation?
 Current pyenchant libraries conflict with GRASS (using older dlls), so if
 the packaging was done centrally I assume that this issue would be
 bypassed?
 Please see: https://github.com/qgis/QGIS/issues/59775 and
 https://github.com/pyenchant/pyenchant/issues/311#issuecomment-1678972867
 Pyenchant can be installed using MINGW so I assume it can be packaged so
 that it does not conflict with other elements:
 https://pyenchant.github.io/pyenchant/install.html#using-mingw
 Happy to help but don't know where to start...
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/874>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
