[osgeo4w-dev] [osgeo4w] #876: saga 9.7.1-1 fails to start (MSVCP140.dll error)
trac_osgeo4w at osgeo.org
Sun Mar 30 05:04:51 PDT 2025
Reporter: andreaerdna | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: critical | Component: Package
Version: | Resolution:
Keywords: |
Comment (by Andreas Müller):
I can't tell what is wrong with your installation, but I check the path,
because Osgeo4w\bin should come before system pathes. That is set usually
by the provided batch files. Try running the Osgeo4w-Shell and from there
call the batch flle of your applications.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/876#comment:4>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
