[osgeo4w-dev] [osgeo4w] #876: saga 9.7.1-1 fails to start (MSVCP140.dll error)
trac_osgeo4w at osgeo.org
Sun Mar 30 23:52:49 PDT 2025
Reporter: andreaerdna | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: critical | Component: Package
Version: | Resolution:
Keywords: |
Comment (by jef):
Replying to [comment:3 andreaerdna]:
> Why GRASS-GIS and SAGA-GIS (and other ones) executable don't use the
msvcp140.dll shipped by OSGeo4W with the msvcrt2019 package (shouldn't it
be named msvcrt2022)? Is there a way to enforce the use of the one shipped
by OSGeo4W instead of the one installed in the system (apart from copying
the msvcp*.dll in the same folder of the executable)?
No. That's the problem. QGIS (and python) use AddDllDirectory internally
to make sure system32 doesn't take priority over PATH - but that's not the
default. By default t directory of a DLL or EXE has the highest priority
- that's why copying the runtime everywhere helps, then system32, then
whatever is in PATH.
My question is why this is a problem all of a sudden on some machines.
I'm not aware of any updates in OSGeo4W that would cause this. Installing
the latest runtime would require admin rights, but I don't think that the
latest one is even required - any not too ancient one should do - so I
wonder why/if/how you got yours.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/876#comment:6>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
