[osgeo4w-dev] [osgeo4w] #894: Uninstalling python3-shapely package doesn't completely removes all related folders and files
OSGeo4W trac_osgeo4w at osgeo.org
Mon Oct 6 04:37:33 PDT 2025
folders and files
Reporter:  andreaerdna  |      Owner:  osgeo4w-dev@…
    Type:  defect       |     Status:  new
Priority:  normal       |  Component:  Package
 Version:               |   Keywords:
 1. install the qgis-ltr module (the python3-shapely package is correctly
 not automatically installed)
 2. start QGIS -> QGIS starts correctly
 3. close QGIS
 4. install the python3-shapely module
 5. start QGIS -> QGIS starts correctly
 6. close QGIS
 5. uninstall the python3-shapely module
 6. start QGIS -> see the following error:
 Couldn't load SIP module.
 Python support will be disabled.
   File "", line 1, in
   File "C:\OSE37B~1/apps/qgis-ltr/./python\qgis\__init__.py", line 85, in
     import qgis.gui
   File "C:\OSE37B~1/apps/qgis-ltr/./python\qgis\gui\__init__.py", line 26,
 in
     from qgis.core import Qgis as _Qgis
   File "C:\OSE37B~1/apps/qgis-ltr/./python\qgis\core\__init__.py", line
 22903, in
     def _geometry_as_shapely(self) -> _sg.base.BaseGeometry:
 AttributeError: module 'shapely.geometry' has no attribute 'base'
 Python version:
 3.12.11 (main, Jun 17 2025, 13:41:12) [MSC v.1943 64 bit (AMD64)]
 QGIS version:
 3.40.11-Bratislava 'Bratislava', df059ed19c
 Python path:
 ['C:/OSE37B~1/apps/qgis-ltr/./python',
 'C:/Users/Andrea/AppData/Roaming/QGIS/QGIS3\\profiles\\qgis340ltr_E/python',
 'C:/Users/Andrea/AppData/Roaming/QGIS/QGIS3\\profiles\\qgis340ltr_E/python/plugins',
 'C:/OSE37B~1/apps/qgis-ltr/./python/plugins',
 'C:\\OSE37B~1\\apps\\grass\\grass84\\etc\\python',
 'C:\\Users\\Andrea\\Documents', 'C:\\OSGeo4W_V2_E\\bin\\python312.zip',
 'C:\\OSE37B~1\\apps\\Python312\\DLLs',
 'C:\\OSE37B~1\\apps\\Python312\\Lib', 'C:\\OSGeo4W_V2_E\\bin',
 'C:\\OSE37B~1\\apps\\Python312', 'C:\\OSE37B~1\\apps\\Python312\\Lib
 \\site-packages', 'C:\\OSE37B~1\\apps\\Python312\\Lib\\site-
 packages\\win32', 'C:\\OSE37B~1\\apps\\Python312\\Lib\\site-
 packages\\win32\\lib', 'C:\\OSE37B~1\\apps\\Python312\\Lib\\site-
 packages\\Pythonwin']
 It looks like the issue is due to the fact that, uninstalling the
 python3-shapely package, the files and folders related to the "shapely"
 Python module are incorrectly non removed from the \Python312\Lib\site-
 packages folder.
 In fact, after the python3-shapely package in uninstalled, the "shapely"
 folder, containing other subfolders and various *.pyc files, is still
 present in the \Python312\Lib\site-packages folder.
 Removing the "shapely" folder and the contained files and subfolders,
 prevents the issue to occur.
 See also https://trac.osgeo.org/osgeo4w/ticket/871.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/894>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
