[osgeo4w-dev] [osgeo4w] #894: Uninstalling python3-shapely package doesn't completely removes all related folders and files and then QGIS starts without Python support
OSGeo4W trac_osgeo4w at osgeo.org
Tue Oct 7 11:04:07 PDT 2025
Reporter:  andreaerdna  |       Owner:  osgeo4w-dev@…
    Type:  defect       |      Status:  new
Priority:  normal       |   Component:  Package
 Version:               |  Resolution:
Keywords:               |
Description changed by andreaerdna:
Old description:
> 1. install the qgis-ltr module (the python3-shapely package is correctly
> not automatically installed)
> 2. start QGIS -> QGIS starts correctly
> 3. close QGIS
> 4. install the python3-shapely module
> 5. start QGIS -> QGIS starts correctly
> 6. close QGIS
> 5. uninstall the python3-shapely module
> 6. start QGIS -> see the following error:
> Couldn't load SIP module.
> Python support will be disabled.
> Traceback (most recent call last):
>   File "", line 1, in
>   File "C:\OSE37B~1/apps/qgis-ltr/./python\qgis\__init__.py", line 85, in
>     import qgis.gui
>   File "C:\OSE37B~1/apps/qgis-ltr/./python\qgis\gui\__init__.py", line
> 26, in
>     from qgis.core import Qgis as _Qgis
>   File "C:\OSE37B~1/apps/qgis-ltr/./python\qgis\core\__init__.py", line
> 22903, in
>     def _geometry_as_shapely(self) -> _sg.base.BaseGeometry:
> AttributeError: module 'shapely.geometry' has no attribute 'base'
> Python version:
> 3.12.11 (main, Jun 17 2025, 13:41:12) [MSC v.1943 64 bit (AMD64)]
> QGIS version:
> 3.40.11-Bratislava 'Bratislava', df059ed19c
> Python path:
> ['C:/OSE37B~1/apps/qgis-ltr/./python',
> 'C:/Users/Andrea/AppData/Roaming/QGIS/QGIS3\\profiles\\qgis340ltr_E/python',
> 'C:/Users/Andrea/AppData/Roaming/QGIS/QGIS3\\profiles\\qgis340ltr_E/python/plugins',
> 'C:/OSE37B~1/apps/qgis-ltr/./python/plugins',
> 'C:\\OSE37B~1\\apps\\grass\\grass84\\etc\\python',
> 'C:\\Users\\Andrea\\Documents', 'C:\\OSGeo4W_V2_E\\bin\\python312.zip',
> 'C:\\OSE37B~1\\apps\\Python312\\DLLs',
> 'C:\\OSE37B~1\\apps\\Python312\\Lib', 'C:\\OSGeo4W_V2_E\\bin',
> 'C:\\OSE37B~1\\apps\\Python312', 'C:\\OSE37B~1\\apps\\Python312\\Lib
> \\site-packages', 'C:\\OSE37B~1\\apps\\Python312\\Lib\\site-
> packages\\win32', 'C:\\OSE37B~1\\apps\\Python312\\Lib\\site-
> packages\\win32\\lib', 'C:\\OSE37B~1\\apps\\Python312\\Lib\\site-
> packages\\Pythonwin']
> It looks like the issue is due to the fact that, uninstalling the
> python3-shapely package, the files and folders related to the "shapely"
> Python module are incorrectly non removed from the \Python312\Lib\site-
> packages folder.
> In fact, after the python3-shapely package in uninstalled, the "shapely"
> folder, containing other subfolders and various *.pyc files, is still
> present in the \Python312\Lib\site-packages folder.
> Removing the "shapely" folder and the contained files and subfolders,
> prevents the issue to occur.
> See also https://trac.osgeo.org/osgeo4w/ticket/871.
New description:
 3. close QGIS
 6. close QGIS
   File "", line 1, in
     import qgis.gui
   File "C:\OSE37B~1/apps/qgis-ltr/./python\qgis\gui\__init__.py", line 26,
 in
 22903, in
 Python version:
 QGIS version:
 Python path:
 packages folder.
 See also #871.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/894#comment:2>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
