[osgeo4w-dev] [osgeo4w] #894: Uninstalling python3-shapely package doesn't completely removes all related folders and files and then QGIS starts without Python support
OSGeo4W trac_osgeo4w at osgeo.org
Wed Oct 8 14:46:01 PDT 2025
Reporter:  andreaerdna  |       Owner:  osgeo4w-dev@…
    Type:  defect       |      Status:  new
Priority:  normal       |   Component:  Package
 Version:               |  Resolution:
Keywords:               |
Comment (by andreaerdna):
 After uninstalling python3-shapely (ensuring that no instances of QGIS are
 running), there is still a {{{shapely}}} folder in {{{\apps\Python312\Lib
 \site-packages\}}}.
 Such folder contains the following files and folders:
  Directory di C:\OSGeo4W_V2_E\apps\Python312\Lib\site-
 packages\shapely\algorithms
 08/10/2025  23:28    <DIR>          .
 08/10/2025  23:28    <DIR>          ..
 08/10/2025  23:27    <DIR>          __pycache__
                0 File              0 byte
 packages\shapely\algorithms\__pycache__
 08/10/2025  23:27    <DIR>          .
 08/10/2025  23:27    <DIR>          ..
 08/10/2025  23:27             1.385 cga.cpython-312.pyc
 08/10/2025  23:27             2.514 _oriented_envelope.cpython-312.pyc
 08/10/2025  23:27               172 __init__.cpython-312.pyc
                3 File          4.071 byte
 packages\shapely\geometry
                0 File              0 byte
 packages\shapely\geometry\__pycache__
 08/10/2025  23:27            44.551 base.cpython-312.pyc
 08/10/2025  23:27             2.149 collection.cpython-312.pyc
 08/10/2025  23:27             4.947 geo.cpython-312.pyc
 08/10/2025  23:27             7.687 linestring.cpython-312.pyc
 08/10/2025  23:27             4.229 multilinestring.cpython-312.pyc
 08/10/2025  23:27             3.937 multipoint.cpython-312.pyc
 08/10/2025  23:27             4.872 multipolygon.cpython-312.pyc
 08/10/2025  23:27             5.521 point.cpython-312.pyc
 08/10/2025  23:27            15.548 polygon.cpython-312.pyc
 08/10/2025  23:27               947 __init__.cpython-312.pyc
               10 File         94.388 byte
 packages\shapely\__pycache__
 08/10/2025  23:27             9.071 affinity.cpython-312.pyc
 08/10/2025  23:27            41.375 constructive.cpython-312.pyc
 08/10/2025  23:27             8.328 coordinates.cpython-312.pyc
 08/10/2025  23:27             3.384 coords.cpython-312.pyc
 08/10/2025  23:27            22.200 creation.cpython-312.pyc
 08/10/2025  23:27             4.256 decorators.cpython-312.pyc
 08/10/2025  23:27             3.508 errors.cpython-312.pyc
 08/10/2025  23:27            14.020 io.cpython-312.pyc
 08/10/2025  23:27             7.938 linear.cpython-312.pyc
 08/10/2025  23:27            11.000 measurement.cpython-312.pyc
 08/10/2025  23:27            35.846 predicates.cpython-312.pyc
 08/10/2025  23:27            18.258 set_operations.cpython-312.pyc
 08/10/2025  23:27            21.542 strtree.cpython-312.pyc
 08/10/2025  23:27             1.275 _enum.cpython-312.pyc
 08/10/2025  23:27            27.204 _geometry.cpython-312.pyc
 08/10/2025  23:27            19.050 _ragged_array.cpython-312.pyc
 08/10/2025  23:27               549 _version.cpython-312.pyc
 08/10/2025  23:27             1.149 __init__.cpython-312.pyc
               18 File        249.953 byte
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/894#comment:5>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
