[osgeo4w-dev] [osgeo4w] #894: Uninstalling python3-shapely package doesn't completely removes all related folders and files and then QGIS starts without Python support
trac_osgeo4w at osgeo.org
Thu Oct 9 16:51:57 PDT 2025
Reporter: andreaerdna | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: normal | Component: Package
Version: | Resolution:
Keywords: |
Comment (by andreaerdna):
I'm using the "Setup" shortcut link (which points to setup.bat) in the
Windows Start menu.
Please have a look at the screen recording available at
https://drive.google.com/file/d/1vWwhwj6YIwDnNx9XrqaCQxOl-cbRxBDH/view
that shows:
- QGIS starting correctly without python3-shapely
- QGIS starting correctly after python3-shapely is installed using Setup
- QGIS throwing the error {{{AttributeError: module 'shapely.geometry' has
no attribute 'base'}}} at startup
- QGIS starting correctly after removing the leftover "shapely" folder in
{{{\apps\Python312\Lib\site-packages\}}}
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/894#comment:7>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
