[osgeo4w-dev] [osgeo4w] #929: Vulnerable Postgresql 18.4 components included with OSGEO4W install
trac_osgeo4w at osgeo.org
Fri Aug 14 04:20:53 PDT 2026
Reporter: ascottwwf | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: normal | Component: Package
Version: | Keywords:
Hello,
I have become aware that our QGIS LTR installations v3.44.13 contain
Postgresql v18.4 components (we use the OSGeo4W installer to install /
maintain QGIS LTR onto our devices),
Postgresql 18.4 contains 24 published Security vulnerabilities (CVEs), a
list of these which affect v18.0 and later can be found here:
https://www.postgresql.org/support/security/18/
These flaws carry CVSS v3 scores of between 3.8 (Low) and 8.8 (High)
The affected files are all found in our default installation folder
"C:\Program Files\OSGeo4W_v2\bin"
Evidence of the affected files (using Powershell):
cd "C:\Program Files\OSGeo4W_v2\bin\"
Get-ChildItem libpq.dll,*pg_*.exe -Recurse -Force -ErrorAction
SilentlyContinue | Select-Object * -ExpandProperty versioninfo | Sort-
Object ProductVersion,FileVersionRaw,Filename | Select-Object
ProductVersion,FileVersionRaw,Filename,FileDescription,CompanyName,LegalCopyright
| fl
ProductVersion : 18.4
FileVersionRaw : 18.0.4.0
FileName : C:\Program Files\OSGeo4W_v2\bin\libpq.dll
FileDescription : PostgreSQL Access Library
CompanyName : PostgreSQL Global Development Group
LegalCopyright : Portions Copyright (c) 1996-2025, PostgreSQL Global
Development Group. Portions Copyright (c) 1994, Regents of the University
of California.
FileName : C:\Program Files\OSGeo4W_v2\bin\pg_dump.exe
FileDescription : pg_dump - backup one PostgreSQL database
of California.
FileName : C:\Program Files\OSGeo4W_v2\bin\pg_dumpall.exe
FileDescription : pg_dumpall - backup PostgreSQL databases
of California.
FileName : C:\Program Files\OSGeo4W_v2\bin\pg_restore.exe
FileDescription : pg_restore - restore PostgreSQL databases
of California.
Please can I request that the Postgresql components included with OSGeo4W
Installer be updated to a later version without impacting / breaking other
dependencies (suggest 18.6 - Release Notes:
https://www.postgresql.org/docs/release/18.6/)
Thanks in advance,
Regards,\\
Adrian Scott | EUC Specialist, WWF-UK\\
WWF-UK, The Living Planet Centre, Rufford House,\\
Brewery Road, Woking, Surrey GU21 4LL | wwf.org.uk
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/929>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
