[osgeo4w-dev] [osgeo4w] #903: qgis / qgis-ltr: untwine and pdal_wrench crash on Windows 10 (MSVCP140.dll error)
OSGeo4W trac_osgeo4w at osgeo.org
Sun Feb 15 11:20:10 PST 2026
error)
Reporter:  andreaerdna  |       Owner:  osgeo4w-dev@…
    Type:  defect       |      Status:  new
Priority:  normal       |   Component:  Package
 Version:               |  Resolution:
Keywords:               |
Comment (by andreaerdna):
 Some other info.
 When I've installed qgis-ltr 3.40.14-1 and qgis 3.44.6-1, the following
 packages versions, in particular, were also installed:
 pdal / pdal-libs 2.9.0-4
 gdal / gdal312-runtime / python3-gdal 3.12.1-1
 arrow-cpp / python3-pyarrow 19.0.1-1
 poppler 25.02.0-1
 Using **qgis-ltr 3.40.14-1 and qgis 3.44.6-1** with such old packages
 versions, neither untwine.exe nor pdal_wrench.exe crashes.
 After updating only pdal / pdal-libs to 2.9.3-1, then untwine.exe crashes,
 whereas pdal_wrench.exe doesn't crash.
 After updating only gdal / gdal312-runtime / python3-gdal to 3.12.1-2,
 arrow-cpp / python3-pyarrow to 23.0.1-1 and poppler to 26.01.0-1 (they
 need to be updated together), then pdal_wrench.exe crashes, whereas
 untwine.exe doesn't crash.
 After updating all the packages to new versions, then both untwine.exe and
 pdal_wrench.exe crash.
 Adding msvcp140.dll in apps/qgis-ltr/ and apps/qgis/
 - with new packages versions: untwine.exe crashes, whereas pdal_wrench.exe
 doesn't crash.
 Using **qgis-ltr 3.40.15-1 and qgis 3.44.7-1** with old or new packages
 versions, both untwine.exe and pdal_wrench.exe crash.
 - with old packages versions: neither untwine.exe nor pdal_wrench.exe
 crash
 doesn't crash.
 Using **qgis-ltr-dev 3.40.15-409 and qgis-rel-dev 3.44.7-666** with old or
 new packages versions, both untwine.exe and pdal_wrench.exe crash.
 Adding msvcp140.dll in apps/qgis-ltr-dev/ and apps/qgis-rel-dev/
 - with old packages versions: untwine.exe stil crashes whereas
 - with new packages versions: neither untwine.exe nor pdal_wrench.exe
 crash
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/903#comment:3>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
