[osgeo4w-dev] [osgeo4w] #909: Qt Designer doesn't start (MSVCP140.DLL error)
OSGeo4W trac_osgeo4w at osgeo.org
Mon Feb 16 03:53:41 PST 2026
Reporter:  andreaerdna  |       Owner:  osgeo4w-dev@…
    Type:  defect       |      Status:  new
Priority:  normal       |   Component:  Package
 Version:               |  Resolution:
Keywords:               |
Old description:
> Qt Designer doesn't start due to the crash of qtdesigner.exe on my on
> Windows 10 Home 1903 18362.778
> Nome dell'applicazione che ha generato l'errore: designer.exe, versione:
> 5.15.13.0, timestamp: 0x67867377
> Nome del modulo che ha generato l'errore: MSVCP140.dll, versione:
> 14.32.31332.0, timestamp: 0x8b64702c
> Codice eccezione: 0xc0000005
> Offset errore 0x00000000000132f8
> ID processo che ha generato l'errore: 0x3ab4
> Ora di avvio dell'applicazione che ha generato l'errore:
> 0x01dc9f1d2fdda833
> Percorso dell'applicazione che ha generato l'errore:
> C:\OSE37B~1\apps\qt5\bin\designer.exe
> Percorso del modulo che ha generato l'errore:
> C:\WINDOWS\SYSTEM32\MSVCP140.dll
> ID segnalazione: 08feda49-256d-4228-a34e-c75e8f5b4fc3
> Nome completo pacchetto che ha generato l'errore:
> ID applicazione relativo al pacchetto che ha generato l'errore:
> It occurs for "Qt Designer with QGIS 3.40.15 custom widgets", "Qt
> Designer with QGIS 3.44.7 custom widgets" and "Qt Designer with QGIS
> 3.99.0 custom widgets (Nightly)"
> The issue doesn't occur after downgrading gdal312-runtime from 3.12.1-2
> to 3.12.1-1 or copying the file msvcp140.dll from apps/bin/ to
> apps/Qt5/bin/ and apps/Qt6/bin/
> The issue has also been reported by another user using Windows 11: see
> the thread at https://lists.osgeo.org/pipermail/qgis-
> user/2026-February/056092.html
New description:
 0x01dc9f1d2fdda833
 It occurs for "Qt Designer with QGIS 3.40.15 custom widgets", "Qt Designer
 with QGIS 3.44.7 custom widgets" and "Qt Designer with QGIS 3.99.0 custom
 widgets (Nightly)"
 The issue doesn't occur after downgrading gdal / gdal312-runtime /
 python3-gdal to 3.12.1-1, arrow-cpp / python3-pyarrow to 19.0.1-1 and
 poppler to 25.02.0-1, or copying the file msvcp140.dll from bin/ to
 The issue has also been reported by another user using Windows 11 with
 Microsoft Visual C++ 2015-2022 Redistributable (x64) 14.36.32532: see the
Comment (by andreaerdna):
 Actually, even without downgrading gdal, arrow and poppler, or copying the
 file msvcp140.dll from apps/bin/ to apps/Qt5/bin/, Qt Designer itself
 starts without issues if lunched with the command "designer.exe" from the
 OSGeo4W Shell, however in that case the QGIS custom widgets will not be
 available.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/909#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
