[osgeo4w-dev] [osgeo4w] #926: error: 12057 when installing OSGEO4W
trac_osgeo4w at osgeo.org
Tue Jun 16 09:42:13 PDT 2026
Reporter: ThierryL | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: normal | Component: Installer
Version: | Keywords:
Either through GUI or Command line (osgeo4w-setup.exe -q -k -r -A -s
https://download.osgeo.org/osgeo4w/v2/ -P proj).
Would not show mirror sites. Would not download. Finally found log that
showed that error 1205 appeared for every request.
Resolved on my PC (Windows 11 Pro build 10.0.2620) by
temporarily unchecking
Internet Options -> Advanced -> Security
_ Check for Publisher's certificate revocation
_ Check for server certificate revocation
_ Check for signatures on downloaded programs
_ Warn about certificate address mismatch
Did not investigate further.
Once working, these are the first few output lines from this command:
D:\Downloads>osgeo4w-setup.exe -q -k -r -A -s
D:\Downloads>Starting OSGeo4W install, version 2.579
using locales .1252
Current Directory: C:\Users\thier\AppData\Local\Temp
Root Directory: C:\OSGeo4W
Could not open service McShield for query, start and stop. McAfee may not
be installed, or we don't have access.
root: C:\OSGeo4W
Selected local directory: C:\Users\thier\AppData\Local\Temp
Menu name: OSGeo4W
net: Direct
Loaded cached mirror list
get_url_to_membuf https://download.osgeo.org/osgeo4w/ssl/mirrors.lst
getUrlToStream https://download.osgeo.org/osgeo4w/ssl/mirrors.lst
User-Agent: default is "OSGeo4W-Setup/2.579 (Windows NT
6.2.9200;Win64;0409)"
Request for URL https://download.osgeo.org/osgeo4w/ssl/mirrors.lst
satisfied from cache
site: https://download.osgeo.org/osgeo4w/v2/
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/926>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
