[osgeo4w-dev] curl incorrectly flagged as non-open-source in OSGeo4W installer
Tobias Wendorff
tobias.wendorff at tu-dortmund.de
Wed Mar 25 02:10:44 PDT 2026
Dear OSGeo4W team,
while installing QGIS via the OSGeo4W installer, I noticed that the
package "curl" is now prompting users for explicit consent due to
supposedly restrictive license terms. The package appears to be tagged
as non-open-source, which is incorrect.
curl is open source in every meaningful sense. Its license is
functionally almost identical to the MIT or BSD licenses - permissive,
attribution-based, and widely accepted. The likely source of confusion
is that the SPDX identifier "curl" (used for curl's specific license
variant) is not explicitly listed as an approved license by the Open
Source Initiative (OSI). However, this is a gap in OSI's list, not a
reflection of curl's actual licensing terms.
For reference, the curl project's copyright and license information is
documented here: https://curl.se/docs/copyright.html
The lead developer of curl is very approachable and responsive - he can
be reached via IRC, among other channels, if clarification is needed
directly from the source.
I would suggest reviewing the license classification logic in the
installer and correcting the tag for the curl package accordingly.
Thank you for your time and for maintaining OSGeo4W!
Best regards
Tobias
More information about the osgeo4w-dev
