[osgeo4w-dev] Offline installer from cache not working
Jürgen E. Fischer
jef at norbit.de
Wed May 13 08:35:07 PDT 2026
Hi Marwan,
On Thu, 23. Apr 2026 at 11:01:38 +0000, BADAWI Marwan via osgeo4w-dev wrote:
> Then I created a local cache folder using the package list from the
> installed.db file using the following command: osgeo4w-setup.exe --quiet-mode
> --arch x86_64 --autoaccept --no-desktop --download --local-package-dir
> C:\OSGEO_CACHE --site http://www.norbit.de/osgeo4w/v2 --packages $PkgList
No need to mess with installed.db. To fetch packages including dependencies on
a connected machine run (qgis-full as example; corresponding with the QGIS
Express install target):
mkdir packages
cd packages
curl -JLO https://download.osgeo.org/osgeo4w/v2/osgeo4w-setup.exe
osgeo4w-setup.exe --quiet-mode --autoaccept --arch x86_64 --local-package-dir %CD% --download -s https://download.osgeo.org/osgeo4w/v2 --packages qgis-full
Then copy packages to the unconnected machine and run:
cd packages
osgeo4w-setup.exe --quiet-mode --autoaccept --arch x86_64 --local-package-dir %CD% --local-install --packages qgis-full
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden https://www.norbit.de
QGIS release manager (PSC) Germany Matrix: @jef:osgeo.org
Desc: not available
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20260513/03d18d2c/attachment.sig>
More information about the osgeo4w-dev
