[osgeo4w-dev] Offline installer from cache not working
Jürgen E. Fischer
jef at norbit.de
Mon May 18 03:08:44 PDT 2026
Hi Marwan,
On Mon, 18. May 2026 at 08:39:20 +0000, BADAWI Marwan wrote:
> Here is the full process I am running:
> 1 - Perform an express install and select QGIS and GDAL components. Everything is working and this is what I am trying to reproduce (if there is an easier way to duplicate this, I am all for it).
> 2 - Recover the installed.db file from that install.
> 3 - Create an offline cache using the installed.db file and running the following command : osgeo4w-setup.exe --arch x86_64 --quiet-mode --autoaccept --no-desktop --local-package-dir C:\osgeo_cache --packages $(pkg_list) --download --site http://www.norbit.de/osgeo4w/v2 --site http://download.osgeo.org/osgeo4w/v2 --site http://ftp.osuosl.org/pub/osgeo/download/osgeo4w/v2
> 4 - Uninstall the manually installed version
> 5 - Install with the following command: osgeo4w-setup.exe --arch x86_64 --quiet-mode --autoaccept --no-desktop --local-package-dir C:\osgeo_cache --packages $(pkg_list) --root C:\OSGeo4W --local-install
As said:
mkdir packages
cd packages
curl -JLO https://download.osgeo.org/osgeo4w/v2/osgeo4w-setup.exe
osgeo4w-setup.exe --quiet-mode --autoaccept --arch x86_64 --local-package-dir %CD% --download -s https://download.osgeo.org/osgeo4w/v2 --packages qgis-full
and then copying packages to an unconnected machine and running:
cd packages
osgeo4w-setup.exe --quiet-mode --autoaccept --arch x86_64 --local-package-dir %CD% --local-install --packages qgis-full
works fine for me. No need to preinstall and mess with installed.db and
--no-desktop is default anyway. But your package list also works for
me. That's apparently not the problem. setup.log or setup.log.full might have
more information.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden https://www.norbit.de
QGIS release manager (PSC) Germany Matrix: @jef:osgeo.org
Desc: not available
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20260518/e8211688/attachment.sig>
More information about the osgeo4w-dev
