[osgeo4w-dev] [osgeo4w] #923: SAGA: Function GDALRegister ... did not register a driver ... (it needs to be built against GDAL 3.13)
OSGeo4W trac_osgeo4w at osgeo.org
Tue May 19 07:20:15 PDT 2026
Reporter:  andreaerdna  |       Owner:  osgeo4w-dev@…
    Type:  defect       |      Status:  closed
Priority:  normal       |   Component:  Package
 Version:               |  Resolution:  fixed
Keywords:               |
Comment (by jef):
 No experience with SAGA usage. The sdat are apparently zips (now?).  The
 contained sdat as well as the file renamed to .zip can be opened in QGIS.
 I'd say this is a plugin issue.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/923#comment:3>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
