[osgeo4w-dev] [osgeo4w] #923: SAGA: Function GDALRegister ... did not register a driver ... (it needs to be built against GDAL 3.13)
OSGeo4W trac_osgeo4w at osgeo.org
Tue May 19 10:28:09 PDT 2026
Reporter:  andreaerdna  |       Owner:  osgeo4w-dev@…
    Type:  defect       |      Status:  closed
Priority:  normal       |   Component:  Package
 Version:               |  Resolution:  fixed
Keywords:               |
Comment (by andreaerdna):
 wow, what a coincidence! I've installed it just some hours ago from the
 plugins' repository using the plugin manager and I've also seen today the
 plugin Web page and the GitHub repository...
 So, the new SAGA 9.12 could be an issue only for users that are running
 QGIS LTR 3.44 and that have already installed the plugin.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/923#comment:6>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
