[osgeo4w-dev] [osgeo4w] #933: OSGeo4W installing inconsistent proj files
trac_osgeo4w at osgeo.org
Mon Oct 5 12:35:08 PDT 2026
Reporter: thomr | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: normal | Component: Package
Version: | Keywords: proj
On Windows 11, after updating the OSGeo4W installation.
Since then, some proj components seem to be inconsistent between them.
As example, launching the OSGeoW shell :
ogr2ogr -overwrite -f MSSQLSpatial
"MSSQL:server=myServer;database=myDatabase;trustservercertificate=yes;trusted_connection=yes;driver={ODBC
Driver 18 for SQL Server}" "G:\\myFile.shp" -a_srs "EPSG:4326" -lco
"GEOM_TYPE=geography" -lco "LAUNDER=NO" --config MSSQLSPATIAL_USE_BCP
FALSE
I get the following errors :
ERROR 1: PROJ: proj_create_from_database: C:\OSGeo4W\share\proj\proj.db
contains DATABASE.LAYOUT.VERSION.MINOR = 2 whereas a number >= 4 is
expected. It comes from another PROJ installation.
ERROR 1: Failed to process SRS definition: EPSG:4326
Workaround :
Installing a standalone QGis version and using its shell works well.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/933>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
