[Osgeo4w-trac] Re: [osgeo4w] #18: shell package
OSGeo4W trac_osgeo4w at osgeo.org
Fri Jul 4 19:57:14 EDT 2008
#18: shell package
  Reporter:  maphew       |       Owner:  osgeo4w-dev at lists.osgeo.org
      Type:  enhancement  |      Status:  new
  Priority:  major        |   Milestone:
 Component:  Installer    |     Version:
Resolution:               |    Keywords:
Comment (by maphew):
 ''Proof of concept'' - I've never made a package before; I've no idea if
 this is correct. I just copied the structure I could see in the other
 packages. The md5sum is made up.
 1. put the attached shell*.bz2 into `var/cache/...../release/shell/`,
 2. Insert the following into `etc/setup/setup.ini`:
 @ shell
 sdesc: "setup OSGeo4W command shell environment and shortcut"
 ldesc: "setup OSGeo4W command shell environment and shortcut"
 category: Commandline_Utilities
 requires: msvcrt
 version: 0.0-1
 install: ./release/shell/shell-0.0-1.tar.bz2 3145
 8ef010bafbb234ed1f9372e9b50767f6
 3. and run "apt install shell"
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/18#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
