[Osgeo4w-trac] [osgeo4w] #9: libjpeg does not support large files
trac_osgeo4w at osgeo.org
Tue Jun 17 22:20:01 EDT 2008
Reporter: warmerdam | Owner: warmerdam
Type: defect | Status: new
Priority: major | Milestone:
Component: Package | Version:
Keywords: libjpeg |
> I am now down to one last issue with libjpeg and I can use all
> of the osgeo4w depends successfully. Looks like GDAL does the same
> thing in libtiff and uses the cpl port for any IO performed on any input
> jpeg. The only difference I see in the jpeg-6b library I am compiling
> and the one you are compiling is the jconfig.h. When I built the
> libjpeg library I just copied the jconfig.vc file to jconfig.h and then
> built it. In the one that is installed via the osgeo installer I see
> something like this at the top and the contents are different and it
> contains something like this at the top of the file:
> jconfig.h. Generated automatically by configure.
> Was wodnering if we could try the jconfig.h.vc to jconfig.h and see if
> the direct IO use will work.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/9>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac
