[Osgeo4w-trac] Re: [osgeo4w] #2: Add existing MS4W mapscript packages
OSGeo4W trac_osgeo4w at osgeo.org
Tue Jun 24 11:17:13 EDT 2008
  Reporter:  jmckenna  |       Owner:  warmerdam
      Type:  task      |      Status:  new
  Priority:  major     |   Milestone:  Beta Release
 Component:  Package   |     Version:  Alpha
Resolution:            |    Keywords:
Comment (by tamas):
 Replying to [comment:1 warmerdam]:
 > I have packaged [wiki:pkg-mapscript-java].  I have also now packaged
 Python 2.5 and will take care of python mapscript.
 > Perhaps Tamas would be interested in packaging c# mapscript?
 Yes I'm interested in. But I'm a bit hesitant to think it could be done
 without having the same version of the mapserver sources and using the
 same compiler version as for the main builds. My best bet is to use the
 latest stable from SVN and MSVC71 but it won't likely work along with an
 older source versions.
 Or do we have a mapserver-dev package (with libs and headers) along with
 the sources have been used to create it?
 My other concern is the compiler affinity of the C# packages. MapScript C#
 targeting various frameworks like the .NET Framework 2.0 will require to
 use MSVC80 compatible binaries. Is it allowed to host 2 or more different
 versions of the same mapserver package in osgeo4w?
 Best regards,
 Tamas
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/2#comment:3>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
