[Osgeo4w-trac] Re: [osgeo4w] #27: Package gdaI-dev: ippj-5.3.dll
	not found
    trac_osgeo4w at osgeo.org
    Fri Nov 21 09:56:17 EST 2008
#27: Package gdaI-dev: ippj-5.3.dll not found
  Reporter:  klokan         |       Owner:  warmerdam
      Type:  defect         |      Status:  assigned
  Priority:  major          |   Milestone:
 Component:  Documentation  |     Version:
Resolution:                 |    Keywords:  ipp
Comment (by klokan):
 gilligan: This is not a good universal solution.
 The solution should be: delete the directory C:\OSGeo4W, start
 installation again and follow _exactly_ the tutorial from
 http://help.maptiler.org/betatest/. You should select only the package '
 gdal-dev', do not click on any other package. Then everything runs as it
 should...
 FrankW: I think the problem is that people are selecting more packages in
 the Advanced installation and again unselecting them, which is keeping
 dependent libraries selected. Some people are confused from the
 installation... but I don't know how to help them more. Hopefully it will
 get better as soon as GDAL 1.6 will become stable.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/27#comment:4>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac
