[Osgeo4w-trac] Re: [osgeo4w] #44: Gdal/Proj problems with Grass
installation
trac_osgeo4w at osgeo.org
Wed Feb 4 11:16:42 EST 2009
#44: Gdal/Proj problems with Grass installation
Reporter: cnielsen | Owner: osgeo4w-dev at lists.osgeo.org
Type: defect | Status: closed
Priority: major | Milestone:
Component: Installer | Version:
Resolution: fixed | Keywords: grass, qgis
Changes (by cnielsen):
* status: new => closed
* resolution: => fixed
Comment:
Update: the non-test version grass-6.4.0RC3-2 seems to have resolved this
issue. There were still several packages I had to add manually including:
curl, expat, hdf, libjpeg, libmysql, netcdf, ogdi, and xerces.
QGIS seems also to have been fixed, at least for that library. But an
QtCore4 error came up instead. (QtCore4.dll is installed).
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/44#comment:3>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac
