[Osgeo4w-trac] Re: [osgeo4w] #46: Setup shortcut doesn't work after
update
trac_osgeo4w at osgeo.org
Wed Feb 4 15:22:52 EST 2009
#46: Setup shortcut doesn't work after update
Reporter: mwtoews | Owner: warmerdam
Type: defect | Status: closed
Priority: major | Milestone:
Component: Documentation | Version:
Resolution: fixed | Keywords: pkg-setup
Changes (by warmerdam):
* status: assigned => closed
* resolution: => fixed
Comment:
I have fixed this problem, and the upgraded package is now online.
I also fixed it so the start menu entry for setup has an icon file, and
modified the setup.bat and setup-test.bat files so they insert the path
for OSGeo4W root at install time so they work properly outside the OSGeo4W
environment.
It took me three repackagings to get this all working. :-)
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/46#comment:2>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac
