[Osgeo4w-trac] Re: [osgeo4w] #47: Start menu is disorganized
trac_osgeo4w at osgeo.org
Wed Feb 4 22:21:45 EST 2009
Reporter: mwtoews | Owner: osgeo4w-dev at lists.osgeo.org
Type: enhancement | Status: new
Priority: minor | Milestone:
Component: Installer | Version:
Resolution: | Keywords:
Comment (by mwtoews):
Replying to [comment:2 warmerdam]:
> but perhaps you could manually remove all the start menu items, and the
installed OSGeo4W tree and then reinstall to see if the problem occurs
again?
I did this, and it did "clean" it up by removing the second QGIS shortcut,
but I still see the double nesting "OSGeo4W > OSGeo4W > OSGeo4W Shell" as
shown in the original attachment.
> I thought we did have an apache install/restart/uninstall at one point,
but I don't see it on mine.
In OSGeo4W/bin, I see:
apache-install.bat apache-restart.bat apache-uninstall.bat
Maybe the Shell PATH should also include OSGeo4W/apache/bin for the other
Apache related programs from the CMD/msys shells?
Also, I found the handy task bar control at
OSGeo4W/apache/bin/ApacheMonitor.exe which I think is a good candidate EXE
to add to the Start menu.
Finally, it would make sense to group all Apache related programs into
it's own group: Start > OSGeo4W > Apache
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/47#comment:4>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac
