[Osgeo4w-trac] Re: [osgeo4w] #37: grass: wxpython gui issues
trac_osgeo4w at osgeo.org
Mon Feb 23 23:01:04 EST 2009
Reporter: jachym | Owner: osgeo4w-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone:
Component: Package | Version:
Resolution: | Keywords: GRASS
Comment (by hamish):
Replying to [comment:21 martinl]:
> Replying to [comment:19 hamish]:
[wxPython location wizard]
> > So it's just the code browser which is unhappy in the end.
> > But without browsing to fix the "/c/...\epsg" to "C:\...\epsg"
> > it gives me a Traceback error in the DOS console (line 1567
> > KeyError: 4326).
> Hopefully fixed in http://trac.osgeo.org/grass/changeset/35981.
right. I've dropped in the wxpython/ dir from releasebranch_6_4 and it
seems good, I see the list of codes.
but "Search in description" doesn't seem to work.
Should the [Browse EPSG Codes] button there be renamed [Search] ?
clicking that refreshes the list, but it is still at the top.
or do I just press enter in the search text entry box? (does nothing)
If I type in the code manually, everything seems to work, location is
created fine, including correct datum transform questions.
Hamish
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/37#comment:28>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac
