[Osgeo4w-trac] Re: [osgeo4w] #25: gdal_merge
trac_osgeo4w at osgeo.org
Fri Jan 16 19:45:32 EST 2009
#25: gdal_merge
Reporter: ckiko13 | Owner: osgeo4w-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone:
Component: Installer | Version:
Resolution: | Keywords: gdal_merge
Comment (by maphew):
ckiko13: gdal_merge is a python script (gdal_merge.py) and part of the
gdal-python package, so you need to install that also.
leaving the ticket open because gdal-python should probably be installed
by default(?)
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/25#comment:2>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac
