[Osgeo4w-trac] [osgeo4w] #35: DLL installation procedure
OSGeo4W trac_osgeo4w at osgeo.org
Wed Jan 21 15:06:57 EST 2009
 Reporter:  jef        |       Owner:  osgeo4w-dev at lists.osgeo.org
     Type:  defect     |      Status:  new
 Priority:  major      |   Milestone:  1.0 Release
Component:  Installer  |     Version:  1.0
 Keywords:             |
 Some DLLs should be update DLLs in %WINDIR%\system32 instead of just
 installing them into %OSGEO4W_ROOT%, if the are there.
 E.g. it's likely to find an elder version of OpenSSL DLLs in
 %WINDIR%\system32, which breaks everything using SSL (like libcurl and in
 turn GDAL and everything that depends on it). This only applies to
 EXEs/DLLs that are loaded from different path than %OSGEO4W_ROOT%\bin
 (like Python extension, GRASS executables).  About the DLL search order:
 http://msdn.microsoft.com/en-us/library/ms682586(VS.85).aspx
 We should have a tool that can retrieve the version of a DLL and if
 necessary replaces it with a newer one.   I found a code snippet that
 should how to retrieve the DLL version on
 http://www.codeproject.com/KB/DLL/dllversion.aspx
 The update procedure should also consider replace on reboot, if the older
 version of the DLL is currently in use (osgeo4w-setup has code to do
 that).
 A related posting of the qgis-developer list:
 http://lists.osgeo.org/pipermail/qgis-developer/2009-January/005733.html
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/35>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
