[Osgeo4w-trac] Re: [osgeo4w] #37: grass: wxpython gui issues
trac_osgeo4w at osgeo.org
Sat Jan 24 11:43:58 EST 2009
Reporter: jachym | Owner: osgeo4w-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone:
Component: Package | Version:
Resolution: | Keywords: GRASS
Changes (by jachym):
* summary: grass gui missing => grass: wxpython gui issues
Comment:
Replying to [comment:4 jef]:
> the grass-6.4.0RC2-2 package contains the fix
GREAT! GRASS starts now in wxpython mode!
What does not work:
* wx-nviz (no error message, when you switch the monitor to 3D view,
nothing happens)
* wx-v.digit -- Only message I get is
Unable to initialize the display driver, see README file for more
informations.
Details: 'NoType' Object has no attribute 'OpenMap' (no module named
grass6_wxvdigit).
Is the grass6_wxvdigit compiled ?
* when I want to display raster/vector file, only mapsets are listed, but
no maps in the d.rast/vect GUI form. In the command line is:
g.mlist: command not found
(translated from czech-windows to english-unix)
adding raster name manually works
* while starting GUI, first message I get (in the command line):
profile.py:
This module requires the NumPy module,
which could not be imported. It probably is not installed (it's not
part of standard Python distribution). See ....
eventhough numpy can be installed, it is not checked by default. it
should be IMHO checked, when the user requires GRASS automaticaly (as well
as wxpython). afterwards the profiling tool works
* I did not manage to run *any* of raster modules. Nothing happens
simply. Maybe it is the g.mlist issue?
Shall I open new tickets for every of these issues separately?
Some screenshots
* http://les-ejk.cz/tmp/grass_windows_tcltk.png
* http://les-ejk.cz/tmp/grass_windows_wxpython.png
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/37#comment:5>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac
