[Osgeo4w-trac] Re: [osgeo4w] #65: qgis 1.0.1 can't load rpy/rpy2
	interface to R
    trac_osgeo4w at osgeo.org
    Fri Mar 13 18:06:06 EDT 2009
#65: qgis 1.0.1 can't load rpy/rpy2 interface to R
Reporter:  lutra                      |        Owner:  jef
    Type:  defect                     |       Status:  new
Priority:  major                      |    Component:  Package
 Version:  1.0                        |   Resolution:
Keywords:  qgis, 1.0.1, rpy, rpy2, R  |
Comment (by lutra):
 Replying to [comment:2 jef]:
 > What python are you using?  Looks like it's not osgeo4w's python, if you
 had rpy/rpy2 working with that python, it would probably work in QGIS,
 too.
 I see your point. I would like to give a try to your solution, but among
 the dependencies of the R based plugins there is rpy/rpy2 that I cannot
 see in the osgeo4w installer. If I try to install rpy/rpy2 separately it
 says that can't find python in the registry. Any workaround? If missing it
 is possible to add rpy/rpy2 to the osgeo4w installer?
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/65#comment:3>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac
