[Osgeo4w-trac] Re: [osgeo4w] #65: qgis 1.0.1 can't load rpy/rpy2 interface to R
OSGeo4W trac_osgeo4w at osgeo.org
Sat Mar 14 15:41:00 EDT 2009
Reporter:  lutra                      |        Owner:  jef
    Type:  enhancement                |       Status:  new
Priority:  major                      |    Component:  Package
 Version:  1.0                        |   Resolution:
Keywords:  qgis, 1.0.1, rpy, rpy2, R  |
Comment (by jef):
 Replying to [comment:6 aghisla]:
 > ticket #55 refers to missing rpy package inside the installer. Adding it
 will solve the issue above. Otherwise, the installer should locate and use
 already installed python.
 I've packaged python-rpy2.  It's available in the testing area (osgeo4w-
 setup -t) for now.  managerR and the home range plugin now load for me.
 Due to lack of experience with either of them, I can't judge if they work
 correctly now. Please test and report back.
 Carson: I get an error from manageR.  Is that because of R 2.6.8 & rpy2
 2.0.8 instead of rpy <=1.0.3 & R <= 2.6.2?
   File ".../.qgis//python/plugins\manageR\manageR.py", line 65, in run
     d = domanageR.Dialog(self.iface)
   File ".../.qgis//python/plugins\manageR\domanageR.py", line 54, in
 __init__
     set_default_mode(BASIC_CONVERSION)
 NameError: global name 'set_default_mode' is not defined
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/65#comment:7>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
