[Osgeo4w-trac] Re: [osgeo4w] #57: duplicate gdal-grass and
grass-gdal-plugins packages
trac_osgeo4w at osgeo.org
Sat Mar 14 18:06:55 EDT 2009
#57: duplicate gdal-grass and grass-gdal-plugins packages
Reporter: hamish | Owner: osgeo4w-dev at lists.osgeo.org
Type: enhancement | Status: closed
Priority: minor | Component: Package
Version: | Resolution: fixed
Keywords: grass gdal qgis |
Changes (by jef):
* status: new => closed
* resolution: => fixed
Comment:
Replying to [ticket:57 hamish]:
> it is a bit confusing that there is both a gdal-grass and a grass-gdal-
plugins package (by versions I see the second one is gdal v1.6, while
gdal-grass is v1.5)
gdal-grass depends on 1.5 and gdal16-grass depends on 1.6 - there is no
grass-gdal-plugins (anymore?).
qgis-grass-plugin depends on gdal-grass.
gdal16-grass is outdated as there was a qgis-grass-plugin (as there was a
qgis) that depended on GDAL 1.6. I reverted that on an advice from
FrankW.
> Perhaps the grass-gdal-plugins one should be renamed gdal1.6-grass or
otherwise.
If that was the case, I must have already fixed that.
> Also, I notice that the qgis-grass-plugin package depends on both grass
and qgis.
> Do it have to?
Yes, the QGIS grass plugin depends on the GRASS libraries (in the
toolbox).
> I notice in the debian packaging that it only depends on the equivalent
of gdal-grass,
On Debian gdal-grass depends on the full grass package. If I'm not
mistaken
grass rasters should be viewable with just gdal-grass present, it doesn't
need the grass plugin at all.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/57#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac
