[Osgeo4w-trac] Re: [osgeo4w] #63: Qgis does not start - message:
 component not found libssl32.dll
    trac_osgeo4w at osgeo.org
    Sun Mar 15 11:51:44 EDT 2009
#63: Qgis does not start  - message: component not found libssl32.dll
Reporter:  ema                |        Owner:  osgeo4w-dev at lists.osgeo.org
    Type:  defect             |       Status:  new
Priority:  major              |    Component:  Package
 Version:                     |   Resolution:
Keywords:  qgis libssl32.dll  |
Changes (by warmerdam):
  * priority:  blocker => major
  * component:  Installer => Package
Comment:
 Ema,
 I have uploaded the DLL dependency tracking program to:
   http://home.gdal.org/tmp/depends.zip
 If you would like, you can download this, and copy the contained
 depends.exe into the C:\OSGeo4W\bin directory.  Then in the OSGeo4W Shell
 window you can do:
   cd C:\OSGeo4W\apps\qgis\bin
   depends.exe qgis.exe
 This should launch the dependency viewer GUI.  The top left pane is a DLL
 tree.  If you can find from that tree which DLL is attempting to load
 libssl32.dll that might be quite helpful to us.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/63#comment:4>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac
