[Osgeo4w-trac] Re: [osgeo4w] #63: Qgis does not start - message: component not found libssl32.dll
OSGeo4W trac_osgeo4w at osgeo.org
Sun Mar 15 12:43:48 EDT 2009
Reporter:  ema                |        Owner:  osgeo4w-dev at lists.osgeo.org
    Type:  defect             |       Status:  new
Priority:  major              |    Component:  Package
 Version:                     |   Resolution:
Keywords:  qgis libssl32.dll  |
Comment (by jef):
 Replying to [comment:5 ema]:
 > I do not know if I understood correctly
 > I opened qgis.exe from dependency
 > list on the left there are two dll with the application of yellow:
 > - MSVCP90.DLL
 > - MSVCR90.DLL
 > but I tried dependency.exe in a pc where qgis works well and there are
 the same libraries with the yellow question mark!
 That's normal, those DLL are installed somewhere in {{{%WINDIR%\WinSxS}}}
 and found through the assembly.
 {{{libssl32.dll}}} is not referenced by qgis directly.  That reference is
 probably in a DLL some plugin in {{{%OSGEO4W_ROOT%\apps\qgis\plugins}}}
 uses.  Maybe {{{postgresprovider.dll}}} or {{{ogrprovider.dll}}}.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/63#comment:6>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
