[Osgeo4w-trac] Re: [osgeo4w] #63: Qgis does not start - message:
 component not found libssl32.dll
    trac_osgeo4w at osgeo.org
    Sun Mar 15 15:32:22 EDT 2009
#63: Qgis does not start  - message: component not found libssl32.dll
Reporter:  ema                |        Owner:  osgeo4w-dev at lists.osgeo.org
    Type:  defect             |       Status:  new
Priority:  major              |    Component:  Package
 Version:                     |   Resolution:
Keywords:  qgis libssl32.dll  |
Comment (by jef):
 Replying to [comment:7 ema]:
 > I tried to uninstall everything that concerns qgis and osgeo4w
 > I cleaned the registry key
 > I rebooted the pc
 > and the result is always the same: I surrender! :-(
 Looks like your problem isn't directly related to qgis or OSGeo4W at all.
 I suspect that you have some DLL in your {{{%WINDIR%\system32}}} that
 depends on {{{libssl32.dll}}}, which is picked up by some other DLL in
 OSGeo4W instead of the intended DLL in OSGeo4W (we've previously seen such
 things with {{{openssl}}}; see also #35 ff).
 Please check the plugins with {{{depends}}}.  You should find a plugin
 that references {{{libssl32.dll}}}, but indirectly though another DLL on
 your system.
 Alternatively you could also search for a file contains {{{libssl32.dll}}}
 using the Windows Explorer's search facility.  That should also locate
 that apparently broken DLL.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/63#comment:8>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac
