[Osgeo4w-trac] [osgeo4w] #69: Error creating a new GRASS location
inside QGIS
trac_osgeo4w at osgeo.org
Thu Mar 19 13:09:57 EDT 2009
#69: Error creating a new GRASS location inside QGIS
Reporter: doktoreas | Owner: osgeo4w-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Component: Package
Version: | Keywords: grass, qgis, proj
I can get this error on a Vista machine and on a XP one:
- Enable GRASS plugin inside QGIS
- Select new mapset
- Set the path, the name
- In the projection selection, if you select any code QGIS freeze.
This happen also if you use the "search epsg" feature in the same window
Thanks
Luca
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/69>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac
