[Osgeo4w-trac] Re: [osgeo4w] #61: Dependencies not automatically
selected
trac_osgeo4w at osgeo.org
Tue Mar 31 21:39:14 EDT 2009
#61: Dependencies not automatically selected
Reporter: cnielsen | Owner: osgeo4w-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Component: Installer
Version: | Resolution:
Keywords: grass |
Comment (by warmerdam):
The installer loads the installed.db file contents at startup and writes
them back out when it terminates. This causes significant problems if you
delete the OSGeo4W tree while the installer is running - mostly because it
saves an installed.db file indicating many packages are installed that are
not actually installed.
For now the only advice I have is to ensure that the installer is
terminated before clearing the tree.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/61#comment:8>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac
