[Osgeo4w-trac] Re: [osgeo4w] #1: Create custom apache port page
trac_osgeo4w at osgeo.org
Tue Aug 3 13:45:59 EDT 2010
Reporter: jmckenna | Owner: jmckenna
Type: task | Status: assigned
Priority: major | Component: Installer
Version: Alpha | Keywords:
Changes (by jmckenna):
* cc: hhayashi, ksakurai, daisuke, venkat (added)
* owner: osgeo4w-dev@… => jmckenna
* status: new => assigned
Comment:
Hayashi-san and Sakurai-san from OSGeo-JP have created a patch for
setup.exe which contains the following changes:
- on opening dialog change from "Express install" to 2 separate options:
"Express Desktop Install" and "Express Web-GIS Install". Desktop install
will only install QGIS, GDAL, GRASS (and disable the web gis options);
Web-GIS install will only install MapServer, GDAL, and Apache (and disable
the desktop options)
- the Web-GIS dialog allows user to enter an Apache port number, and that
port number is applied to httpd.conf in the post install
- additional fixes for locale/resource/translations
The patch is submitted as one patch file containing all changes above. I
will attach the patch file here. This ticket will be used to test and
apply the patch to the setup code.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/1#comment:3>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac
