[Osgeo4w-trac] Re: [osgeo4w] #1: Create custom apache port page
    trac_osgeo4w at osgeo.org
    Tue Aug  3 21:23:04 EDT 2010
Reporter:  jmckenna  |       Owner:  jmckenna
    Type:  task      |      Status:  assigned
Priority:  major     |   Component:  Installer
 Version:  Alpha     |    Keywords:
Comment(by jef):
 Replying to [comment:3 jmckenna]:
 >  - on opening dialog change from "Express install" to 2 separate
 options:
 >  "Express Desktop Install" and "Express Web-GIS Install".  Desktop
 install
 >  will only install QGIS, GDAL, GRASS (and disable the web gis options);
 >  Web-GIS install will only install MapServer, GDAL, and Apache (and
 disable
 >  the desktop options)
 I don't see an advantage here.  The user can just leave the express
 targets he doesn't want alone.   Why disable some (but still show them
 grayed out)?  And some might even want both desktop and webgis (eg. to use
 QGIS to export mapfiles and mapserver to test them).
 And installing QGIS, GRASS or MapServer should already trigger GDAL.  The
 GDAL express target is for installing the command line tools - so it's
 neither Desktop nor WebGIS.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/1#comment:7>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac
