[Osgeo4w-trac] Re: [osgeo4w] #1: Create custom apache port page
OSGeo4W trac_osgeo4w at osgeo.org
Wed Aug 4 11:29:02 EDT 2010
Reporter:  jmckenna  |       Owner:  jmckenna
    Type:  task      |      Status:  assigned
Priority:  major     |   Component:  Installer
 Version:  Alpha     |    Keywords:
Comment(by hhayashi):
 Hi Jeff,
 Thank you for your testing.
 I modified "uDig and OpenEv greyed out/inactive".
 Replying to [comment:6 jmckenna]:
 > Hayashi-san and Sakurai-san,
 > I have tested the Apache port changes on Windows7 successfully.
 > One problem: for the "Express Web-GIS Install", the "uDig" and "OpenEV"
 items should be greyed out/inactive, similar to "Quantum GIS" and "GRASS".
 Can you make that change and create a new 'setup-patch.txt' file, that
 contains all of the changes compared to current SVN, and attach it to this
 ticket?
 > Once those changes are made I will re-test, and then apply the changes
 to SVN.
 > -jeff
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/1#comment:9>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
